Cam Lobe Offset
SimonBrown
#1 Cam Lobe Offset
Post by SimonBrown » Sun May 11, 2025 7:10 pm
Has anyone come across a camshaft lobe not being central to the tappet guide?
No 1 exhaust lobe (most rearward), is approx 3mm to the left of central, just enough for the lobe to be touching the guide under certain circumstances, and creating a rattle.
Whether this a faulty camshaft I am not sure?
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
#2 Re: Cam Lobe Offset
Post by mgcjag » Sun May 11, 2025 7:20 pm
Hi Simon..the lobe dosnt action the tappet centrally....it strikes it slightly offset....so that the tappet actually turns a bit with each sweep.....if it acted central then the tappet would wear...Steve...PS cam endfloat is taken by the flanges on each side of the front bearing...service manual page B.32
