What is the cover located above the rear axle in the trunk for and what can be repaired or checked there?
PierreW
#1 What is the cover located above the rear axle in the trunk for and what can be repaired or checked there?
Post by PierreW » Mon Jun 30, 2025 5:16 pm
All is in the title: For S1 OTS 3.8l
If anything can be done through this hole......
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
#2 Re: What is the cover located above the rear axle in the trunk for and what can be repaired or checked there?
Post by mgcjag » Mon Jun 30, 2025 5:50 pm
Handbrake adjustment...see service manual..or just remove cover and have a look..Steve
PierreW
#3 Re: What is the cover located above the rear axle in the trunk for and what can be repaired or checked there?
Post by PierreW » Tue Jul 01, 2025 10:07 am
It's so stuck that I didn't want to do unnecessary damage just to see what use it had. Thanks
