My drain channel at the rear boot needs some work. It's rusted out above the number plate, where the drain pipe sits and further along where the inner finisher flange is formed. Can you buy a "U" shaped patch panel for this area. I've Checked the normal suppliers but drawn a blank.
Any advice would be much appreciated
Alun
Boot drain channel
#2 Re: Boot drain channel
The usual reply to this would be to try Monocoque Metalworks. I would expect that Chuck would have an answer .
#3 Re: Boot drain channel
Hi Tim,
Yes monocoque do supply the channel. I was wondering if there was anything in the UK before I took the plunge.
Alun
Alun
Al
Series 1, 2+2
undergoing renovation
Series 1, 2+2
Geoff Allam
#4 Re: Boot drain channel
If Monocoque supplies the channel it would be wise to purchase it as the fit will be correct in all dimensions. It could save you a lot of “fettling”.
Geoff Allam
