Aliexpress ignition system for 6 cylinders Lucas distributor
PierreW
#1 Aliexpress ignition system for 6 cylinders Lucas distributor
Post by PierreW » Fri Jul 11, 2025 9:12 am
Has anyone ever tried using this item? I know it's Chinese but...
https://fr.aliexpress.com/item/10050015 ... Redirect=y
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
#2 Re: Aliexpress ignition system for 6 cylinders Lucas distributor
Post by mgcjag » Fri Jul 11, 2025 9:19 am
Your link just takes me to general items....nothing specific...you have an expensive car..why not give it good parts especially electrics.?..Steve
johnetype
#3 Re: Aliexpress ignition system for 6 cylinders Lucas distributor
Post by johnetype » Sun Jul 13, 2025 11:24 pm
I've got a Chinese distributor, mine came from Simon BBC. It works fine and gave me my first chance to add a distributor with vacuum advance.
I keep it in the car as a spare.
I suggest you source a secondhand Lucas constant energy distributor and coil from a Series 3 XJ6 or move to a 123 or similar as Steve suggests for your main distributor.
1969 Series 2 FHC
PierreW
#4 Re: Aliexpress ignition system for 6 cylinders Lucas distributor
Post by PierreW » Mon Aug 18, 2025 5:20 pm
I ended up buying one and testing it on a bench at ambiant temperature 27°C with a stock coil and 13,2 volt battery on charging.
- 6 hours simulated engine at 5500 rpm: coil temperature 45°C, module temperature 30°C
- 6 hours simulated engine at 800 rpm idle: coil temperature 52°C, ignition module temperature 38°C (normal! It's at idle that it pulls the most).
Interesting: The module interrupts the coil power if the engine isn't running, even if the magnets are facing the sensor, so there's no risk of burning out the coil.
Testing on a real engine has been postponed until I find an original 3.8L distributor to convert... if anyone has a source :-)
Anyway, it works!
