Reverse lamp housing to body gasket/seal
swindler
#1 Reverse lamp housing to body gasket/seal
Post by swindler » Sat Jul 26, 2025 12:58 pm
Hi does anyone know the part number or a source for this? I can’t see on the usuals
3.8 OTS 1964
Original RHD. Close ratio moss box
#2 Re: Reverse lamp housing to body gasket/seal
Post by abowie » Sat Jul 26, 2025 10:28 pm
https://www.sngbarratt.com/English/UK/F ... mbly/21076
13 and 19. Yours appears to be home made.
swindler
#3 Re: Reverse lamp housing to body gasket/seal
Post by swindler » Sat Jul 26, 2025 11:03 pm
Hi numbers 13 and 19 on that diagram are the gaskets for the lens and the plate to the housing.. this is for between the housing and the car body
3.8 OTS 1964
#4 Re: Reverse lamp housing to body gasket/seal
Post by abowie » Sun Jul 27, 2025 3:53 am
Ah yes, I see. I don't think that there is one from factory.
There isn't one in the parts manual.
swindler
#5 Re: Reverse lamp housing to body gasket/seal
Post by swindler » Sun Jul 27, 2025 7:48 am
Thanks - must be improvised to protect body paint. It looks quite neat with the bead/pipe when fitted so I’ll reuse it
3.8 OTS 1964
