Where did the fuse go
#1 Where did the fuse go
Post by DWW » Sun Aug 31, 2025 9:26 pm
When you drop a fuse from position 6 or 7 on the RH banks, where does it go and can it be retrieved?
#2 Re: Where did the fuse go
Post by Gfhug » Mon Sep 01, 2025 6:16 pm
Danny, pick the car up, turn upside down and shake vigorously!
Sadly they can fall anywhere. I use a short, insulated hook to pull a fuse out at one end then it can be pulled out more easily. They are a PITA to pull out.
caveman
#3 Re: Where did the fuse go
Post by caveman » Mon Sep 01, 2025 8:54 pm
Check the bottom, or furthest edge, of the hinge instrument panel. Modern glass fuses can be slightly longer so I slide them along slightly, by squeezing with fingers, then lever out at one end before pulling clear. It helps if youve got piano fingers :lol: Good luck.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#4 Re: Where did the fuse go
Post by DWW » Tue Sep 02, 2025 12:47 pm
:yeahthat: , they fall when trying to re-insert them😁
