Torpedo armrest screws
Knightrider
Topic author - Posts: 98
#1 Torpedo armrest screws
My Series 1 2+2 has torpedo-style armrests. I am trying to figure out the correct size screws to fit them - they currently seem to be fitted with a variety of different wood screws...
Does anyone know a source for correct size screws? Thanks.
1966 Series 1 2+2
1966 Series 1 2+2
#2 Re: Torpedo armrest screws
Hi Simon..have you looked at the parts catalogue for the part number...then check on that....Steve..ps you could remove the door cards and check the threads assuming they arnt damaged...but if someone has used wrong screws the threads could be damaged and need repair
Knightrider
#3 Re: Torpedo armrest screws
Annoyingly the MR catalogue shows the screws coming with the handle, and doesn't lost the screws separately.
I might just re-tap the threads to M5 which seems to be the closest.
1966 Series 1 2+2
1966 Series 1 2+2
#4 Re: Torpedo armrest screws
I have a recall that mine were 1/4 unf. I used Allen headed bolts
Knightrider
#5 Re: Torpedo armrest screws
1/4in definitely too big. Looks like they are just smaller than 5mm...
1966 Series 1 2+2
1966 Series 1 2+2
#6 Re: Torpedo armrest screws
Probably 10/32... Steve
#7 Re: Torpedo armrest screws
I stand corrected!
#8 Re: Torpedo armrest screws
I stand corrected!
Apologies
Apologies
Knightrider
#9 Re: Torpedo armrest screws
I'll order some 10/32 unf and see if they fit...
1966 Series 1 2+2
1966 Series 1 2+2
#10 Re: Torpedo armrest screws
They are 10/32 unf, mine are pan head Pozi about 1.25 inch long.
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
#11 Re: Torpedo armrest screws
From experience I'd recommend you use hex heads, or at least Philips head.
A flat head slotted screw can be hard to keep aligned in the recess in the armrest.
Knightrider
#12 Re: Torpedo armrest screws
Thanks all. Will try hex head if I can find some!
1966 Series 1 2+2
1966 Series 1 2+2
