Repro 3.8 indicator switch C21710
#1 Repro 3.8 indicator switch C21710
Post by abowie » Sat Mar 14, 2026 2:17 am
Having purchased a new indicator switch to replace my original (unfixable) I fitted it.
Only to find that the switch arm rotated in the housing, meaning that I couldn't actuate the switch.
After trying to wick some superglue into the socket without success I removed it (not a quick job) and disassembled it to fix the problem.
With original switches the bottom of the arm is knurled and this provides a firm interference fit into the socket.
BUT. On the repro (as I eventually worked out after some time and swearing) both the socket and the arm are threaded 10/24. Furthermore the threads were loose enough that once it bottomed out it just spun and wouldn't tighten.
So I cleaned out the threads, Araldited it back in place and it now works.
So beware; if yours spins you can just unscrew it from the socket and glue it back in place without having to go to the trouble of removing the switch and disassembling it.
#2 Re: Repro 3.8 indicator switch C21710
Post by mgcjag » Sat Mar 14, 2026 8:46 am
Thanks for posting Andrew
265bhp
#3 Re: Repro 3.8 indicator switch C21710
Post by 265bhp » Sat Mar 14, 2026 9:10 pm
Repro repro….the quality and problems don’t seem to go away….. :mad:
#4 Re: Repro 3.8 indicator switch C21710
Post by Series1 Stu » Sat Mar 14, 2026 11:16 pm
That's because most repro manufacturers have neither the wit nor the wisdom to do the job properly.
Annoying, but unfortunately true.
Sander
Denmark
#5 Re: Repro 3.8 indicator switch C21710
Post by Sander » Tue Mar 17, 2026 11:57 am
I have experienced exactly the same problem as Andrew with the C21710 aftermarket indicator switch. It is simply cheap crap. I also started with superglue, but that didn't work. Then I made the thread longer so there was room for a lock nut, as seen in the photo. It worked for 14 days, then it came loose again. Finally, I also gave it some JB Weld epoxy glue. It worked! But honestly, you pay more than €220 for such crap. I have heard that you can use the newer model C25254 as a replacement for C21710 on older cars also. There is probably a surplus wire, but it should be of significantly better quality.
Jesper
Jesper
E-Type FHC, 1965 * XK120 OTS, 1950 * Volvo P1800S, 1964 * Volvo 145, 1972 * MGB, 1967 * Land Rover S3, 1972
#6 Re: Repro 3.8 indicator switch C21710
Post by abowie » Tue Mar 17, 2026 10:14 pm
C25254 uses the plastic ring to cancel; so you'd need that as well.
