Rev counter generator
Stevemorris
#1 Rev counter generator
Post by Stevemorris » Fri Jun 05, 2026 6:21 am
My rev counter isn’t working, even if I tap it!
I’ve checked across the terminals for a Voltage, zero…
I did hear or read somewhere that you can get these re magnetised, does anyone know where or indeed if it’s possible?
Thanks, Steve.
Steve, UK.
1965 Jaguar ‘E’ Type FHC
tim wood
#2 Re: Rev counter generator
Post by tim wood » Fri Jun 05, 2026 7:59 am
Is it definitely rotating? Not unknown for the drive dog to become distanced from the camshaft
Tim
#3 Re: Rev counter generator
Post by mgcjag » Fri Jun 05, 2026 8:07 am
Or to snap off
Stevemorris
#4 Re: Rev counter generator
Post by Stevemorris » Fri Jun 05, 2026 8:09 am
Thanks chaps,
I have to remove the rearmost cam cap to renew a stud, so I'll check when I do this, and let you know! The drive is still intact Steve I took it off to renew the seal, it is spinning as well, plus I could feel the coupling in the cam and it felt OK?
Steve.
Steve, UK.
Simonpfhc
#5 Re: Rev counter generator
Post by Simonpfhc » Fri Jun 05, 2026 2:03 pm
The generator creates an AC voltage that increases by 1v every 1000rpm. You could try measuring the output first.
62 3.8 FHC
91 Porsche 928GT
Stevemorris
#6 Re: Rev counter generator
Post by Stevemorris » Fri Jun 05, 2026 4:05 pm
Hi Simon, yes already done that and at 1,2,3,4000rpm zero Volts!
Thanks,
Steve.
Steve, UK.
Stevemorris
#7 Re: Rev counter generator
Post by Stevemorris » Mon Jun 22, 2026 10:32 am
Well thanks all. I removed the rear camshaft cap this morning and as Tim mentioned the drive had backed out of the rear of the cam.
I have 'drilled & pinned' it, and it works!
Happy days.
For info the 'pin' was a 1mm x 4mm copper rivet.
Here's a video showing it done.
Thanks again, another job off the list...Steve.
In video 9 I mentioned that the pin was slightly smaller than the hole, I meant bigger..
And after the usual 'tap' to wake the rev counter clock up, it works!
Steve, UK.
