Braided Fuel Lines
kevh
#1 Braided Fuel Lines
Post by kevh » Thu Jun 25, 2026 2:15 pm
When do you replace the braided fuel lines?
You can’t see the condition of the rubber as it is hidden inside the stainless steel braiding.
Kev
#2 Re: Braided Fuel Lines
Post by Gfhug » Thu Jun 25, 2026 6:47 pm
Which braided fuel line and where? My fuel lines are solid or one ‘clear’ line up to the carbs from the fuel filter.
#3 Re: Braided Fuel Lines
Post by bitsobrits » Thu Jun 25, 2026 9:15 pm
I would replace braided rubber based lines at no more than 10 years old, regardless of mileage. And if you have no idea how old it is, I would argue for replacement.
There does exist stainless braided line with nylon or PTFE based interior hose (such as Aeromotive) that should last for decades if there is no mechanical damage.
FWIW I no longer use braided rubber lines due to the unseen deterioration of the inner rubber portion. I just use a quality modern fuel hose and replace it every 5-8 years.
On my E-type specifically, it has the factory nylon lines from tank to pump, aftermarket CuNiFer metal pipe up to the fuel filter, then a short length of rubber hose to the fuel rail for the carbs.
kevh
#4 Re: Braided Fuel Lines
Post by kevh » Mon Jun 29, 2026 1:28 pm
I have the SNG stainless steel braided fuel return pipes on my V12, they are said to be suitable for E5 & E10.
I just wondered what people’s thoughts were regarding lifespan.
Kev
#5 Re: Braided Fuel Lines
Post by Gfhug » Mon Jun 29, 2026 2:54 pm
Kev, it would have been helpful if you had stated it is for an S3 car. Please add your car type to your signature area. Click on your user name top right to do that.
