difficulty fitting pistons with new rings
phoenix
#1 difficulty fitting pistons with new rings
Post by phoenix » Sun Jul 12, 2026 2:27 pm
I have managed to fit two but whatever I do the other four will not go over oil rings. 4.2 by the way used plenty of pil tried three different clamps with no success . i have tried them in the bore and they have the correct gap, I just cant think of anything else.
S1 4.2 RHD Bryan
#2 Re: difficulty fitting pistons with new rings
Post by mgcjag » Sun Jul 12, 2026 3:19 pm
You need a correct size clamp....is yours compressing the rings enough into the pistons....the pistons typically don't just slip in they can take some tapping to get them in......Steve
#3 Re: difficulty fitting pistons with new rings
Post by Gfhug » Sun Jul 12, 2026 3:24 pm
Rob Beere sells his version of a ring compressor to get the pistons in.
madjack4
#4 Re: difficulty fitting pistons with new rings
Post by madjack4 » Sun Jul 12, 2026 4:52 pm
Clamp the rings ensure gaps on rings are staggered drop rod and piston in make SHURE U TAP DOWN CLAMP tight to block face ensure conrod is not hitting crankshaft then tap piston in with hammer shaft making shure ring clamp does not lift away from block or oil rings will pop out
Rob 1972 s3 roadster
Aston Martin DB9 Volante
