VSE L14 cam info
Topic author - Moderator
#1 VSE L14 cam info
Hi All....trying to help someone on JL with their VSE built engine......cant access the VSE info in the Knowledge base for some reason....the question is what should the tappet gaps be set to?....in the build sheet below it shows L14 as the inlet cam....I cant makout that the exhaust is?.....any help appreciated..Steve
#2 Re: VSE L14 cam info
Found the info myself.....managed to extract it from the knowledge base.....strange in the old days many would have jumped in to try and help.....Steve
#3 Re: VSE L14 cam info
But Steve, you know full well you should have looked in the knowledge base first
Our illustrious leader should know all about VSE
#4 Re: VSE L14 cam info
Geoff....as I said I did look in the KB but couldn't access the file.....tried again today and it downloaded
