A/C Fan Speeds on S3 2+2 Coupe
Loyer
#1 A/C Fan Speeds on S3 2+2 Coupe
Post by Loyer » Thu Mar 10, 2011 11:43 pm
My A/C blower fan (not the heater fan) is currently running only "high" and "off" instead of the low, med, high and off. Nothing happens at low and medium switch placement.
A/C works good.
I want to get the 3 speeds back.
Does this sound like a switch problem or is there a resistor (simlar to the green heater fan resistor) in the A/C circuit?
Is the A/C front panel difficult to remove (to get to the switch)? Is it serviceable?
Any advice would be appreciated. Thanks from Canada.
carlv12
Spain
#2
Post by carlv12 » Sat Mar 12, 2011 12:07 pm
Hello,
this failure is due to the air con resistor, part numebr C27267. It's a green tubular part.
When fitting a new one, please avoid the direct contact to any metal surface, because the resistor will be hot when working = it needs air to be cooled.
Regards from Valencia
Carlos
Loyer
Post by Loyer » Sat Mar 12, 2011 3:50 pm
Thank you for the reply. I thought that large green resistor was for the heater blower . That will be an easy fix. thanks again.
