Door Drains
ALAN COCHRANE
#1 Door Drains
Post by ALAN COCHRANE » Tue May 07, 2013 2:28 pm
Hi Everyone
I'm giving my S1 Roadster a complete interior refurb including the door panels.
I came across an old thread from 2008 on this forum concerning door drain ducts. This included handy photos of the underside of one door and the fitment of two pop riveted "ducts" to divert rainwater away from the sills. My doors seem to be missing these ducts.
The thread also mentioned the old Jaguar part nos BD 20978 & 20979 for these items. I phoned SNG and they had nothing listed under these numbers. Can anyone help solve this mystery.
Alan
Post by Heuer » Tue May 07, 2013 2:47 pm
Try Hutson's!
They also supply the door drain outlets (but no part numbers - just ask)
Front
Rear
ALAN COCHRANE
#3 DOOR DRAINS
Post by ALAN COCHRANE » Wed May 08, 2013 12:22 pm
David
Thanks for the info. I contacted Hutson's and they have ordered a set for me. I was very impressed with the service and would certainly use them again.
Alan
Post by Heuer » Wed May 08, 2013 12:40 pm
I mentioned to Julian Barratt that the normal Forum response to requests for unusual parts was "Try Hutsons!". He said Hustons secret weapon was Andy Rayner and that was difficult to replicate.
Post by Heuer » Sun May 12, 2013 6:11 pm
Just remembered - Angus took this photo whilst we were down at E-Type UK. It shows the water deflectors (black) and the door drain outlets (body colour) which are often missing on restored cars. Angus was most intrigued by the 'patch' fitted over the window winder spring which he had never seen before.
Part numbers are:
BD20978 Sealing plate front x2
BD20979 Sealing plate rear x2
BD 1814/2 Pop rivet securing sealing plates to doors x14
Door drain outlets have no part numbers, but Hutsons can supply if you describe them.
tinworm
Post by tinworm » Sun May 12, 2013 6:24 pm
Some cars did have these covers to the winder mechanism - I thought they were for the later cars but cannot be specific . I have one of these covers somewhere or other !
regards Barrie
Post by 1954Etype » Sun May 12, 2013 6:42 pm
That photo also clarifies the debate we had earlier on here about the water reflectors (the black panels).
david muir
Scotland
#8 Door water deflectors
Post by david muir » Mon May 13, 2013 9:05 am
My car does not have these water deflectors. Have done a part number search on the 'main' suppliers' websites and cannot find them-anyone know where I can get them?
Post by Heuer » Mon May 13, 2013 9:41 am
Try Hutson's! It worked for Alan:
ALAN COCHRANE wrote:David
Alan
Actually it is probably better to use the self adhesive membrane found on modern cars because if you need access to the inner door it is a real pain to drill out those rivets and even more of a pain to get the bits out of the door bottoms to stop them rattling around.
nottsman
#10 Re: Door Drains
Post by nottsman » Mon Sep 04, 2017 7:10 am
Just wanted to clarify on this subject of door drain outlets. If you fit them, do you still need to cut the cill rubber seal adjacent to door drain in the door?
Secondly, if you just cut the rubber, can you get away from not fitting the outlets?
Thanks,
Nick
1969 S2 2+2
#11 Re: Door Drains
Post by mgcjag » Mon Sep 04, 2017 8:37 am
Hi Nick....i have the drain outlets fitted and no cuts in the rubber seals......ideally you need the outlets fitted. cant see that just cutting the seal wont stop water running in.. Steve
#12 Re: Door Drains
Post by Heuer » Mon Sep 04, 2017 9:17 am
The drains must be fitted - the rubber is cut around them so as not to block the water.
#13 Re: Door Drains
Post by mgcjag » Mon Sep 04, 2017 9:31 am
Are we talking about the same thing......im refering to the small covers fitted at the bottom of the doors....when the doors are closed the rubber seal on the body cill presses up against them.....the outlet at the bottom diverts water below the rubber seal....Steve
You can see the indent in the rubber....NB this is a S2 2+2
#14 Re: Door Drains
Post by Heuer » Mon Sep 04, 2017 9:52 am
Yes. Jaguar specified cut outs in the rubber after complaints the doors needed to be slammed to shut properly. This allowed the drains to move against the seals without distorting the rubber as you can see in the SPC diagram:
#15 Re: Door Drains
Post by mgcjag » Mon Sep 04, 2017 10:01 am
Hi David....thats interesting.....never sure about that bottom rubber seal....when i first got my car the rubber was upside down and stuck out under the bottom of the door....so turned it around and as you see in my photo above it sticks up.......where as in your drawing it points out.....when i re trimmed last year i tried again and this was the only position i came up with that worked......will try to check part number for the seal....is it different for the 2+2s Steve
Edit.....this is the S1 section but Nicks car and mine are both S2 2+2....looks like a different seal section is used....for the S1 S2 S3 2+2 and S3 roadster BD28447 from what i can find this seal is fitted pointing up as in my photo above........but S1 S2 use BD24789 and is fitted pointing out as in Davids photo above.....dont trust me on this im not an expert..... Steve
nottsman
#16 Re: Door Drains
Post by nottsman » Mon Sep 04, 2017 10:17 am
Thanks Steve. Did you buy them or make them yourself?
They look simple enough to make out of a sheet of stainless steel or aluminium.
Cheers,
Nick
1969 S2 2+2
#17 Re: Door Drains
Post by mgcjag » Mon Sep 04, 2017 10:24 am
Hi Nick these are the ones on my S2 2+2 they were on the car when purchased
nottsman
#18 Re: Door Drains
Post by nottsman » Mon Sep 04, 2017 5:45 pm
Thanks Steve. :thankyouyellow:
Nick
1969 S2 2+2
ETTony
#19 Re: Door Drains
Post by ETTony » Mon Sep 04, 2017 7:18 pm
Remember the hose draining the front top of the door, from the hole at the right.
One of my hoses has come off, I hope to get at it in the winter I will try taking the window frame out ?
Tony in Devon
ALAN COCHRANE
#20 Re: Door Drains
Post by ALAN COCHRANE » Thu Sep 07, 2017 4:18 pm
Tony
No need to take the door glass out to refit the hose. Just engage one of your local street urchins or failing that your delicately handed wife to do the job. My better half wondered what all the fuss about lack of space was all about when she kindly reattached the drivers door hose after I had inadvertently detached it.
Alan
Alan Cochrane
