Stoneguards
stretoo
#1 Stoneguards
Post by stretoo » Tue Nov 05, 2013 2:13 pm
Hello all.
I would like to make the 2 stoneguards, numbers 23 and 26 on the picture (parts # BD20048 and BD274427) as they are missing on my car.
By chance does anybody have the measures/template or blueprint for these two parts?
Many thanks in advance.
Stephane
FHC 1966
Post by christopher storey » Tue Nov 05, 2013 7:15 pm
They are not very easy to make. I tried and failed to make a decent job of it, and eventually I found that Hutsons in Bradford could supply them
Dave K
Post by Dave K » Tue Nov 05, 2013 7:24 pm
To save you a huge amount of bother and to get a decent job Robey's, SNGB or Hutson sell them and they are cheap enough to make you want to buy not make.
stretoo
Post by stretoo » Wed Nov 13, 2013 11:49 am
Some nice people sent me the accurate templates. So I do not need further information. Thanks
Stephane
FHC 1966
Dave K
Post by Dave K » Wed Nov 13, 2013 1:08 pm
Looks like I'm off the Christmas card list :D
stretoo
Post by stretoo » Fri Nov 15, 2013 5:15 pm
Job done using 8/10 mm aluminium sheet:
Stephane
FHC 1966
Post by Heuer » Fri Nov 15, 2013 5:35 pm
St?phane
You are missing a piece. There is a cover plate on the 4.2's which goes over the oblong cut-out, held in place by a screw going into a nylon nut. Should be easy enough to make from the picture alone.
stretoo
Post by stretoo » Fri Nov 15, 2013 5:48 pm
Thanks David. By any chance do you have a picture of it in situ?
I will close the aperture with a removable part as I have a spin on/off oil filter fitted.
Stephane
FHC 1966
Post by PeterCrespin » Fri Nov 15, 2013 6:51 pm
stretoo wrote:Job done using 8/10 mm aluminium sheet:
Very nice work. How much do you charge? :-)
Dave K
Post by Dave K » Fri Nov 15, 2013 9:01 pm
Ahem, Pete my old mate I just happen to have a set made out of ali. Someone sent me the patterns for them and the heat shields off a 2+2 and when I told him how much I never heard back so they might be for sale if I don't hear back soon.
Post by PeterCrespin » Fri Nov 15, 2013 11:07 pm
I might be in the market then.
stretoo
Post by stretoo » Fri Nov 15, 2013 11:14 pm
Thanks Pete. No business here just fun but if you come around my place place with a sheet of aluminium (23.90 ? for a 600X1000 mm) I'll be happy to make an additionnal set for you to thank you for the advices/tips you gave me when I needed.
PS: If you come with your D Type I'll provide the aluminium :D
Stephane
FHC 1966
stretoo
Post by stretoo » Fri Nov 15, 2013 11:30 pm
Well Dave apparently you didn't follow your own recommendations: "To save you a huge amount of bother and to get a decent job Robey's, SNGB or Hutson sell them and they are cheap enough to make you want to buy not make." :D
Stephane
FHC 1966
Dave K
Post by Dave K » Fri Nov 15, 2013 11:51 pm
I wouldn't make them for my car because my car has vents in, the 2+2 ones I have as a pattern don't. I was only doing it as a favour in a job lot of heat shields.
How much do they cost new? I don't know but at my works rate of over ?30 / hr plus material costs, it's just not worth the effort.
stretoo
Post by stretoo » Sat Nov 16, 2013 12:07 am
Dave K wrote:I wouldn't make them for my car because my car has vents in, the 2+2 ones I have as a pattern don't. I was only doing it as a favour in a job lot of heat shields.
You are right Dave and I agree.
In my case the work rate is 0 ?/ hr and I spent about 23 ? for a 600x1000 mm aluminium sheet. So it was economically viable although that was not the main consideration for doing it myself.
Stephane
FHC 1966
Patrick NICOLAS
Post by Patrick NICOLAS » Mon Nov 18, 2013 11:29 am
Many thanks St?phane for the template that I received this morning.
I have a fun job for this winter :D
stretoo
Post by stretoo » Wed Nov 20, 2013 7:36 pm
You are welcome.
Many thanks also to Chris Vine who helped me a lot with the templates.
Stephane
FHC 1966
