Oil leak advice
Arbington
#1 Oil leak advice
Post by Arbington » Wed Jan 08, 2014 6:13 pm
Hi all
Before I rush into this could anyone advise where the oil leak may be from on the attached pic?
It looks almost like it could be from the head gasket but I can't see it being that. There's a stud behind the distributor which the oil is possibly running down.
Doesn't seem to be the cam cover or timing cover.
It's a 1968 4.2 series 1.5
1968 series 1.5. 4.2 Old English white
Post by 1954Etype » Wed Jan 08, 2014 6:17 pm
Have got copper washers on those studs?
FLYV
Slovakia
Post by FLYV » Wed Jan 08, 2014 7:47 pm
I had the same problem.I had there copper washers but it was still leaking,then I used same style nuts as used on cam cowers and it is no more leaking.
Arbington
Post by Arbington » Wed Jan 08, 2014 8:26 pm
you are right chaps. There are no copper washers fitted to these underside studs.
ChrisC
Post by ChrisC » Thu Jan 09, 2014 12:19 pm
sadly thats normal. I vaguely recall that the stud goes through the head and sits in a small well of oil so eventually the oil works its way down the thread. Its hard to clean out in situ but I tend to use some stud stealant when I fit them.
To be fair mine still leaks so I just keep wiping it clean. A copper washer will help. Same for the other side...
1964 FHC 4.2
Post by abowie » Fri Jan 10, 2014 9:01 am
ChrisC wrote: A copper washer will help. Same for the other side...
Sandwich the copper washer between the head and an normal steel one.
Moeregaard
Post by Moeregaard » Fri Jan 10, 2014 1:48 pm
You can also use AN-365 nuts to prevent oil from sneaking past the threads. These nuts have a fiber insert that is more resistant to heat than those with the nylon insert. They're available from any aircraft supplier and cost about the same as the hardware-store stuff.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
64etype
Post by 64etype » Fri Jan 10, 2014 5:02 pm
SELOC brand washers should also do the trick.
Eric
