I found a metric part on my E-Type engine !
Durango2k
#1 I found a metric part on my E-Type engine !
Post by Durango2k » Sun Feb 23, 2014 9:58 pm
... I really tried it, used any near- that-size spanner but none did fit.
Finally I gave up, and went to my old metric toolbox, took a 14 + 15 mm sized open wrench, and went back to the block.
YES !
It?s a 15 mm ... fit !
And which item on the 1966 S1 engine block is it ?
It?s the water tap !
That?s a metric item- the FIRST I found IIRC on this car to be metric !
Carsten
Post by 1954Etype » Sun Feb 23, 2014 10:10 pm
Not metric. Probably BSP, Whitworth or some such
Durango2k
Post by Durango2k » Sun Feb 23, 2014 10:15 pm
Okay, but then a 15 mm fits PERFECTLY... :-)
(It?s always good to have a lot of standards around so that you can choose one !)
Carsten
Post by PeterCrespin » Sun Feb 23, 2014 11:23 pm
5/16 Whitworth is 15mm IIRC. 7/16 AF is 1/4 Whit I think. Haven't used many Whit spanners since my pre 65 Brit motorbike days.
There are metric threads on your engine and elsewhere, but the tap is not one of them.
