I finally received the 1962 Moss Gearbox to install on my e-
type 1963. It has massive play in the horizontal direction,
constant pinion shaft, 1/8''. The reason for this movement is
that the bearing outer ring is loose on the housing.
Is it ok to install this transmission the way it is?
I posted a video on youtube showing the outer bearing ring
moving in the housing. See link below:
ANY COMMENTS ARE VERY WELCOME!
Cheers,
Fred
