S2 Headlamp Flasher
iani
#1 S2 Headlamp Flasher
Post by iani » Fri Apr 04, 2014 4:50 pm
Having got all my other electrics working I still can't figure out how I am supposed to flash my headlights. I believe it is by pulling on the indicator switch but this sounds the horn, as does pushing the switch towards the column. I have tried the main/dip switch but it does nothing unless the lights are on obviously. Do I have a fault or am I missing something here?
Ian
E-type - TBC
1968 Triumph GT6 Mk1
Post by Heuer » Fri Apr 04, 2014 5:13 pm
You have a fault. Pulling the indicator stalk towards you should flash the lights. Horn should work from the horn push. Check the wiring on the indicator switch.
iani
Post by iani » Fri Apr 04, 2014 5:28 pm
My horn should work by pushing the indicator stalk towards the column, this is what the handbook says, this is an S2.
E-type - TBC
Simon P
Post by Simon P » Fri Apr 04, 2014 5:28 pm
Heuer wrote:Horn should work from the horn push
Not on an S2. The horn push is purely decorative...
Post by Heuer » Fri Apr 04, 2014 5:32 pm
Missed that bit! Still a problem with the switch wiring I reckon.
chrisvine
Post by chrisvine » Fri Apr 04, 2014 6:14 pm
For S2:
Pushing the end of the indicator stalk towards the column activates the horn: Purple/Black wire is earthed completing the low current relay circuit & therefore activating the relay
Pulling the indicator stalk toward you flashes the main beam: connecting Blue/Yellow wire to Brown
1969 S2 OTS, Elise S1
iani
Post by iani » Fri Apr 04, 2014 6:58 pm
Thanks, I'll take a look at the wiring.
Ian
E-type - TBC
