Rebuild IRS
Spark
#1 Rebuild IRS
Post by Spark » Sun Jul 20, 2014 7:18 pm
Rebuilding the rear end
Couple of questions ref washers
1 Should the outer fulcrum shaft have a washer on the outside of the cradle
2 same again should the inner fulcrum shaft have a washer on the outside of the cradle
When removed the iris had some with and without
Any pics or help please
All catalogues don't show any
Post by abowie » Sun Jul 20, 2014 10:42 pm
I think that you are correct; they are not factory fitted.
Having said that I have fitted them on both my IRS rebuilds; I don't like to tighten nuts down onto fresh powdercoat.
rfs1957
Post by rfs1957 » Mon Jul 21, 2014 8:10 am
My feeling too. The hardened steel shims (0.5mm are good ones) from Ducati engines make brilliant thin, unobtrusive and slippery seatings ......... ask your local Dealer for a poke around in his Magic Box ! Mine's got 35 years' worth in it.
Spark
Post by Spark » Mon Jul 21, 2014 8:44 pm
Agree will find some washers as don't want to spoil powder coat
