Buried under quite a bit of junk
Hard top
First daylight in a few years
Paul.
It could take a few days for your car to show up on xkedata as Paul (Lofty) has to go through quite a few cars and verify them before adding them. Lawyers etc!Paul190H wrote:Alan, I did load the data and photos on XKE data last night but it's not showing yet.
Paul.
Same place on mine.kingzetts wrote:It may also be on the left side rear side panel in the trunk area (that's where it is on my OTS 850626), where there's a small oval plate riveted to the sheet metal.
Exactly right, thanks.kingzetts wrote:It may also be on the left side rear side panel in the trunk area (that's where it is on my OTS 850626), where there's a small oval plate riveted to the sheet metal.
David, I do not believe ours are Bluemels, They have no nameplete but the name is punched into the aluminium. I have a poor I phone photo of it sent to me but will get a better one for you. There is a bit to much paint on the plate to make out the manufacturer but will have a better look this week.Heuer wrote:Behind the rear number plate. Will be held on by two rivets and should be oblong in shape. Whilst you are there any change you could give me some details on the rear plate itself? I am interested if it has a makers name on it (typically Bluemels) and if it just a flat plate or whether it has a raised edge. The original Bluemels plates are very rare and I am having difficulty finding one to add to our Factory Fit thread.
