Steering wheel nut
urpethdj
#1 Steering wheel nut
Post by urpethdj » Sun Aug 03, 2014 8:15 am
I am wanting to remove the steering wheel to polish the aluminium. I took of the horn, but couldn't get into the large nut.
Can anyone advise what the nut size is and best way to get at it?
Post by Heuer » Sun Aug 03, 2014 10:24 am
There should be two parts - a spring lock-nut and a normal nut. They are both the same size but if they are lined up the hex socket will slip over both and make removal difficult. So you need to feed the hex socket in carefully and remove the spring nut first. You should then have access to the main nut. Once both are removed you may still have some difficulty getting the wheel off as it is not only on a spline but also held by two conical pieces. Loosen the knurled steering wheel lock and pull the wheel sharply towards you and it should release but be careful not to lose the two conical wedges.
urpethdj
Post by urpethdj » Sun Aug 03, 2014 4:13 pm
Thank you.
Do you know the size of the nuts?
Post by Heuer » Sun Aug 03, 2014 4:33 pm
Can't recall the size but 1" I think.
36 = Palnut
34 = main nut
33 = bits that will fall out when you remove the wheel
urpethdj
#5
Post by urpethdj » Mon Aug 04, 2014 6:39 am
Brilliant thank you.
