Simple effective pressure bleeding for brakes
#1 Simple effective pressure bleeding for brakes
Post by abowie » Sun Sep 14, 2014 12:18 am
Bleeding the E type brakes, especially with a new system with a lot of air in it can be very difficult.
The use of a urinary catheter syringe has revolutionised this process for me. I replaced a brake servo on my S1 4.2 yesterday, and went from scratch to hard pedal in about 10 mins. I used just under 500ml of fluid, 240ml for flushing, the rest for refilling the reservoir bottles, although it would be wise to have a litre available.
These syringes are designed for flushing urinary catheters. They hold 60ml and differ from normal Luer-Lok syringes in that they have a much larger diameter conical tip. This is a perfect size to make a good push fit into the brake reservoir hose. I steal them from work but I'm sure you could buy them from any pharmacy or Ebay.
A note about reservoirs. On 3.8 cars each master has its own reservoir. On most 4.2 cars the reservoir attached to the brake master cylinder supplies the front calipers. The servo reservoir supplies the rear calipers. This is apparently reversed on some early 4.2s but won't affect bleeding as long as you know which reservoir serves front and rear. You can tell by tracing the metal pipes coming from the booster. If you are unsure check the schematic diagram in the manual. If you are wrong you won't be able to inject fluid.
To bleed the brakes:
1. Select either the front or rear reservoir. It doesn't matter which as the systems bleed independently. Using the syringe, remove all the old fluid from the reservoir and discard this fluid.
2. disconnect the reservoir from the end of the hose
3. fill the syringe (or another clean one) with 60ml of brake fluid. The less air in the syringe the better as you will be able to generate more pressure. Push the syringe firmly into the hose.
4. Attach a clear PVC tube about 1m long to the end of the brake caliper nipple. Run the hose so that it loops above the height of the nipple for a small distance before going into a waste container on the ground. The upward section of tube will allow you to see any air bubbles in the fluid.
5. Open the brake nipple. As usual start with the nipple furthest from the reservoir.
6. Forcing the syringe tip firmly into the hose, inject the majority of the 60ml of fluid. Hold the hose very firmly or brake fluid will go everywhere.
I tend to inject the first half of the syringe slowly, then inject more in a jerky, pulsatile fashion to try to dislodge any small bubbles.
If you have a helper they can tell you when no more bubbles are coming out of the PVC tube. You can do this by yourself however; just leave the syringe and inspect the clear tubing on the nipple for bubbles. If you have a few inches of fluid in the tube with no bubbles in it the bleeding has been successful. Keep going, with more syringes of fluid as necessary, until you have no air. Close the bleed nipple and move to the other side. and repeat 3 to 6.
7. Once you have finished the other side, carefully remove the syringe. Carefully add small amounts of fluid into the end of the hose until you can see a meniscus of fluid about half an inch below the end of the hose. If you spill fluid on paintwork don't panic. Just wash it off with lots of water.
8. Reinstall the reservoir onto the hose. There will still be a small bubble of air within the hose. Put about 20ml of fluid into the reservoir. Tap and squeeze the hose until you see no more bubbles emerging into the fluid in the reservoir. Now put the reservoir back into the supporting clamp and refill it with fluid.
kingzetts
Post by kingzetts » Sat Sep 20, 2014 12:14 pm
I just tried Andrew's method for my rear brakes (4.2 spec brakes). Worked perfectly! Great idea,thanks Andrew.
My wife especially is grateful as after spending an hour pumping my brake pedal for me yesterday she was not pleased to hear that the brakes were still spongy and a second round was needed. So I thought I'd give it a go, so she could stay curled up on the couch reading.
John '62 S1 OTS (now sold)
David Oslo
Norway
Post by David Oslo » Mon Sep 22, 2014 7:19 pm
Now that's what I call a syringe.
I'll be buying from e-bay at £5.50 ... it's worth that to keep the wifey happy
http://www.ebay.co.uk/itm/Medical-syrin ... 3cd5dbe16d
David
S2 OTS '70 (arriving)
jonhall88
#4 Re: Simple effective pressure bleeding for brakes
Post by jonhall88 » Tue Sep 19, 2017 6:22 pm
Would this simple device work on a series three E
1974 ser 3
vee12eman
Kiribati
#5 Re: Simple effective pressure bleeding for brakes
Post by vee12eman » Tue Sep 19, 2017 7:59 pm
Hi Jon,
Yes. Very effective too.
Series III FHC
#6 Re: Simple effective pressure bleeding for brakes
Post by politeperson » Tue Sep 19, 2017 8:09 pm
I think they hand them out for free at the VD clinic.
Us Jaguar drivers require the dual purpose use.
jonhall88
#7 Re: Simple effective pressure bleeding for brakes
Post by jonhall88 » Tue Sep 19, 2017 9:32 pm
thanks all will give it a go tomorrow and let you know results
1974 ser 3
jonhall88
#8 Re: Simple effective pressure bleeding for brakes
Post by jonhall88 » Tue Sep 19, 2017 9:35 pm
found the perfect tool, my wifes turkey syringe but it would seem I have to get the big plastic syringe as she got all humpty when I asked, should have just used it and give it a clean she would have been none the wiser
1974 ser 3
vee12eman
Kiribati
#9 Re: Simple effective pressure bleeding for brakes
Post by vee12eman » Tue Sep 19, 2017 10:18 pm
Mmmmm. Turkey with brake fluid basting :shock:
Series III FHC
