Should this panel be flat?
PaulColeman
#1 Should this panel be flat?
Post by PaulColeman » Sat Nov 08, 2014 2:24 pm
Should the rear door shut face be perfectly flat from side to side? I've marked the panel I'm talking about with an arrow here...
Mine has been bodged, sorry - repaired by the previous owner :wink: and it isn't flat from side to side which concerns me! I want to brace the door openings but need to make sure I don't have the wrong shape to start with!!
Can anybody clarify please?
Thanks, Paul.
jag68
Post by jag68 » Mon Nov 10, 2014 7:08 am
On the '67 coupe I'm currently restoring the panel is flat side to side as well as vertically.
1967 E Type coupe
1968 E Type OTS
2007 XKR
andrewh
Post by andrewh » Mon Nov 10, 2014 10:18 am
99% sure it is flat. what you have there is rising rot that has been patched. I guess the repair platel has been welded on top of the other rotten panel and then tapped in to clear the door or dress with filler. not very nice!
1962 3.8 Series One FHC
BAHADORI
Post by BAHADORI » Mon Nov 10, 2014 4:30 pm
Hello
it is totally flat on my car. Here is a picture during restoration.
Good luck.
Jacques
Jacques
E-type serie 1 OTS 1966.
PaulColeman
Post by PaulColeman » Mon Nov 10, 2014 8:25 pm
Thanks all for the clarification. Didn't want to brace the doors if it's not in the right place!!
Yes it's got the typical rot in that area but the repair has been brazed in so loads of heat :?
Paul.
