Front discs - keep or replace?
Markymark
#1 Front discs - keep or replace?
Post by Markymark » Mon Jan 05, 2015 7:46 pm
Hi Guys,
I've been lurking on this forum for a while now and have found it to be very useful.
Last year I imported a 69 OTS and I'm just cracking on with my list of winter jobs.
Whilst working on the front hubs I noticed that the discs look very old, thin and appear to have some edge chips. I think they should be replaced, but nothing was mentioned at the MOT, so wondered what you think?
I'm hoping you'll see some pics below....
Cheers,
David Oslo
Norway
#2
Post by David Oslo » Mon Jan 05, 2015 7:55 pm
I vote for change. Peace of mind. Minor cost. Minor job (DIY).
David
S2 OTS '70 (arriving)
Post by christopher storey » Tue Jan 06, 2015 10:03 am
The discs are very cheap and to change them is the work of an afternoon at most. I would change them
PS I see you already have the hubs off - in that case it's perhaps 20 minutes a side to do
iani
Post by iani » Tue Jan 06, 2015 10:45 am
christopher storey wrote:The discs are very cheap and to change them is the work of an afternoon at most. I would change them
Unless the 'specialist' doing the work manages to shear a calliper mounting bolt resulting in some engineering being required. I took my chap 6hrs to change two discs, funnily enough that was the last piece of work I gave him.
Ian
Jaguar - 1970 S2 2+2 (sold), 1970 S2 FHC, X150 5.0 XKR, x250 XF x2 (sold) XF SportBrake
1968 Triumph GT6 Mk1
Post by PeterCrespin » Tue Jan 06, 2015 2:25 pm
iani wrote:Unless the 'specialist' doing the work manages to shear a calliper mounting bolt resulting in some engineering being required. I took my chap 6hrs to change two discs, funnily enough that was the last piece of work I gave him.
Ian
The feeling may be mutual. I somehow doubt he purposely sheared off your bolt just to annoy you and charge you extra. In circumstancesz like this - which are extremely common on classic cars (especially in rust-prone climates) - traders typically under-charge. Often they do not recover their true hours, let alone aggravation. If you want by-the-book predictability then run a modern car.
I'm not saying the guy wasn't an idiot or a shyster, but I strongly suspect he was neither and it was all just par for the course. We sometimes forget things don't go according to plan. When you've worked on classic vehicles forty-odd years it's almost a bonus when it does...
Markymark
Post by Markymark » Tue Jan 06, 2015 2:50 pm
Thanks for the replies guys. I've ordered my new disks....
Red Kite
Post by Red Kite » Tue Jan 06, 2015 3:19 pm
Does anyone know what the "wire" in the middle of the S2 discs is for.
Also, is it possible to get replacements like that ?
Gerry.
S2 FHC 1R20003
jagman1970
Post by jagman1970 » Tue Jan 06, 2015 3:39 pm
I believe the wire is an anti-squeal ring. I bought 2 genuine Jaguar discs about 15 years ago and they were difficult to source then.
regards
Keith
Keith
1970 2+2 owned 40 years, 348TS
db7gtgrigio
Post by db7gtgrigio » Sat Jan 10, 2015 10:02 am
I replaced my S2 original discs 4 years ago as like the OP they had chips on the edges. Was unable to find original spec replacements with the anti squeal wire so I bought a pair of solid ones from SNGB which were surprising cheap 25 quid each from memory. Great performance and no squeal whatsoever, so I would say but new and don't worry
Chris, Sydney AUS
1969 4.2 FHC 1R20280
