Many of you followed my fun wet weekend in November 2014 when I removed a cylinder head from a relatively low mileage, (61,808 miles), 1984 Series III fuel injected 4.2 Sovereign. The full story was in the Technical topic under "Removing Cylinder Head studs in situ" in November 2014 as I sought advice on the best way to tackle the challenge. As a relaxing winter workshop job, I removed the cams and valve gear and then had the head glass blasted - followed by some welding done to fill the two unwanted rear water ways and to plug some minor corrosion. I then took the head to my local machine shop friend Fred to be skimmed and the valve seats cut to accept my new inlet and exhaust valves. Fred skimmed the head and confirmed the valve guides were fine and set about cutting the seats, but I got a call from him tonight to say the exhaust seats were done, but the inlet valves I supplied were too big.
Having checked my old inlet valves for the first time - big red face now !!! - I found these were the "normal" 1 3/4 inch and not the "big valve" 1 7/8 inch size. So how come I was blinded by the fuel injection, the low mileage car and no apparent later work to the car, the "PI" cast in the head - which I assumed meant fuel injection, all the inlet valves had the later valve seals which I thought were only on these Series III heads - and the head had the smaller valve seats, spring retainers and collets.
So, either this car has had a modified earlier head fitted with inlet valve seals which would make that were there three types of inlet valve for the 4.2 engine ? An early larger collet 1 3/4 inch dia, a smaller collet 1 3/4 inch dia and a smaller collet 1 7/8 inch dia ?
Either way, I still have a spare head, but I will need to order the 2nd of these valves to rebuild this head, if someone can confirm the two types of 1 3/4 inch valves and just for fun speculate on the history of this fuel injected car.
Photo of the head being removed with the fuel injection:-
Things were looking so good then !!!
After blasting. The head was blasted with the cam covers on and the pipe insulation is only there to protect the cam bucket surfaces :-
What really threw me - the "PI" casting - what is this all about ???
This does not normally happen to me, but I hold my hand up as an example of always checking the obvious !!
Cheers,
