The only big thing that needs to be done is the wheels. I have 3 flat wire wheels and one curly. There is some rust on them so i was thinking of replacing them. Found a very nice set of flat hub wheels on ebay in germany but they are 6 inch k. I don't now where the k stands for but i'm afraid they will touch the bump stop on the inside.
If i look on the mws website they mention backspacing. Is this the important size to tell if they will touch the bump stop? Because the 6 inch wheels sometimes have less backspacing then the 5inch. So the clearance with the bump stop should improve?
There is also a set of curly hub ser1 for sale, but the backspacing is less then the backspacing of the flat hub wheels. Will this give a problem on a ser2 car?
Thanks for your idea's
