Where to put a jack
lowebird
#1 Where to put a jack
Post by lowebird » Sun Apr 05, 2015 9:53 am
Chaps,
After looking through other posts, I have come to the conclusion that the jacking points were not replaced when my car was rebuilt so, can anyone please advise where are the "strong points" where it is safe to use a small hydraulic jack for wheel changing, also, where is a safe place to use a trolley jack at the front so as to get both wheels off the ground?
Thank you in advance,
Reg ( Lowebird ) :)
andrewh
Post by andrewh » Sun Apr 05, 2015 9:59 am
make up a bit of wood the size of the channel on the front picture frame and place it in the "U" section and then jack up from here. DO NOT mistake for the radiator support bracket or else you will get 2 large dents in the top of your bonnet from the top radiator shroud support studs! Its a bit of a fiddle guiding the block and jack into position but by far the best way to jack up the front
1962 3.8 Series One FHC
Post by mgcjag » Sun Apr 05, 2015 10:16 am
lowebird
#4 jacking points
Post by lowebird » Mon Apr 06, 2015 6:41 pm
Steve,
Thanks very much for your help.
Reg
andrewh
Post by andrewh » Mon Apr 06, 2015 8:40 pm
Don't mention it! :?
bopperd
Post by bopperd » Tue Apr 07, 2015 3:32 am
FWIW, I made up this block for jacking up my car about 25 years ago. It's a chunk of spruce 4" x 4", 16" long, with a 1" wide strip of 3/8" plywood nailed on the centre of one face.
The plywood strip fits in the bottom channel of the picture frame, keeping the block from sliding around, but the load is borne by the 4x4. The extra height allows the bonnet to open even with the floor jack still in place.
Like me, it's crude but effective.
Dave Schinbeckler
'61 E-type OTS
'05 X-type Estate
'88 Ferrari Testarossa
'82 Dodge W-150
