Squeaking Brakes
Markymark
#1 Squeaking Brakes
Post by Markymark » Mon May 04, 2015 11:33 am
I am hoping you can help. I've just finished refurbishing the front brakes on my S2 OTS and have an annoying brake squeal that happens when the brakes warm up.
I've changed disks, pads, calipers and anti rattle clips. There is copper grease between pads and Pistons too.
Really not sure what else to do. Hoping someone here has some experience that can help. Anti squeal shims maybe?
Thanks,
Post by Heuer » Mon May 04, 2015 12:17 pm
What pads are you using?
Markymark
Post by Markymark » Mon May 04, 2015 12:54 pm
I'm using mintex ones. It was what SNG Barratt supplied.
Cheers,
Post by PeterCrespin » Mon May 04, 2015 1:21 pm
Use the brakes frequently and hard to bed the pads in and note any improvement. If none, file a slight chamfer on the leading edge. Retest.
Post by Heuer » Mon May 04, 2015 1:25 pm
Or try Greenstuff pads.
Markymark
Post by Markymark » Mon May 04, 2015 1:49 pm
Ok guys, thanks for the prompt responses. Will try to bed them in with some hard use first and see how I get on....
