RHD Mirror Jaguar E-type
Henkie
Netherlands
#1 RHD Mirror Jaguar E-type
Post by Henkie » Thu Jun 25, 2015 4:57 pm
Hello,
Does anyone know where I can buy an "OLD" RHD E-type series II mirror that mounts on the door?
I Have a '69 LHD E-type but when I reverse I miss the second (or third) mirror!
Yes you can buy them new, but they have a black plastic frame around them....
Post by mgcjag » Thu Jun 25, 2015 5:49 pm
Hi Henkie......have a look here...i know they are new but they do not all heve the black plastic......also search on door mirror here on the forum....lots of options http://texautomotive.com/classic_exterior_mirrors.html
Henkie
Netherlands
Post by Henkie » Thu Jul 02, 2015 10:13 am
Thanks MGCJAG. I did contact TEX but as all new mirrors the glass is held by plastic.
I thinks I need to go to a used parts sale meeting.
vee12eman
Kiribati
#4
Post by vee12eman » Sun Jul 05, 2015 1:55 pm
I did a lot of searching for door mirrors for Series 3 cars, if I am right, then those fitted to early Series 3 are the same as those fitted to Late Series 2 and possibly all Series 2 cars.
If these are the mirrors you seek (see forum topic below):
viewtopic.php?t=2042&postdays=0&postord ... r&start=20
then my conclusion was that SNG Barratt have the best solution. The mirror glass is held in place with a black surround. You can see it in the top post of the page linked above, alongside some other designs from other sources.
Series III FHC
RogerM
Post by RogerM » Sun Jul 05, 2015 2:37 pm
Hi Henke
If the mirror you refer to is a Tex type, they were standard fitment on many Leyland Cars of the period including Minis and Triumphs.
I bought mine from Somerford Mini Ltd, stock code GAM215A for about ?20, but I already had the door fitting.
Contact +44(0)1249721421
Look on the website www.somerfordmini.co.uk , search using stock code to confirm it is the type you require.
They specialise in mail order.
Roger
Roger McEwen
S2 FHC Green
Triumph TR6 Mimosa
Henkie
Netherlands
#6 Mirror
Post by Henkie » Mon Jul 06, 2015 11:51 am
I sent you a PM Simon
vee12eman wrote:Hi,
Nickleback
Post by Nickleback » Sat Jul 18, 2015 8:03 am
Hi Henkie,
I also have the same problem on my 1970 XKE S2 FHC (now converted to RHD). I need an original (on what was the passenger door) mirror complete with no black plastic inserts as the current one angles down and in too much, so I cannot see properly behind.
The angle of the arm behind where it joins the mirror back points downward, therefore the mirror cannot be tilted upward or outward enough ?
Can you let us know the resolution you find.
Thx
Mike
Mike,
1970 S2 FHC 2R28165
