as my thermostat (Otter switch) was not working I decided to change it
when I unscrew the first nut, the stud broke right away
I didn't previously spray WD40 as the apparent part of the stud coming out of the nut was "clean" (see right part of the pic)
but alas the internal part of the stud (see left side of pic) was badly rusted
I have since then generously sprayed WD40 but I'm hesitating to go further and unscrew the 2 remaining ones; better 1 permanetly on thermostat than a permanently leaking radiator
what would you suggest ? any way to replace the stud ? need to weld a new oene ? (I hate welding)
