Mangoletsi wire throttle upgrade 1.5 :)
Vegard
Norway
#1 Mangoletsi wire throttle upgrade 1.5 :)
Post by Vegard » Sun Aug 16, 2015 8:23 pm
I'm also in the process fitting such a kit, but I've encountered a problem.
There is a vacuum pipe in the way. Have I got the proper E-type manifold?
I'm changing the American Str?mbergs for triple SUs in the same process you see.
Will I need to blank the vacuum ports?
68 1.5 FHC, 65 4.2 FHC, 72 MGB GT, 6 Minis, 71 Escort1300GT, 65 BMW Neue Klasse, 62 Volvo P1800 and a 205 GTI
Simonpfhc
Post by Simonpfhc » Sun Aug 16, 2015 8:33 pm
You have a 3.8 manifold but looks like a Mangoletsi kit for a 4.2.
62 3.8 FHC
91 Porsche 928GT
Vegard
Norway
Post by Vegard » Sun Aug 16, 2015 10:21 pm
Well, the car is a series 1.5 4.2. I guess I need a different inlet then.
Are these easy to come by?
Did the Mangoletsi kit come for 3.8s as well?
Simonpfhc
Post by Simonpfhc » Mon Aug 17, 2015 6:23 am
In that case, yes, you will need the 4.2 manifold. They do come up on ebay every now and then.
62 3.8 FHC
91 Porsche 928GT
Post by 1954Etype » Mon Aug 17, 2015 6:34 am
The inlet manifold you have is one of the very early 3.8 types which is more valuable than the later type. You might be able to sell the entire setup for the same price of a new Burlen kit.
David Oslo
Norway
#6
Post by David Oslo » Mon Aug 17, 2015 7:16 am
On Finn (the Norwegian exchange & mart) there has been a few sellers of 4.2 engines the last months, one for sure is from an E-type (I bought his gearbox and flywheel). Maybe they could sell just the inlet, or worst case you buy the entire engine and sell off the other parts. Let me know if you can't find the adverts.
Then sell your valuable 3.8 manifold on eBay in UK. Nice exchange rate right now. And a keen buying market.
Maybe you'll make enough to pay for the throttle conversion kit too !
David
S2 OTS '70 (arriving)
Vegard
Norway
#7
Post by Vegard » Mon Aug 17, 2015 9:38 am
Isn't this the same as mine?
http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-US
Looks very similar.
Thanks for the feed back guys!
Post by PeterCrespin » Mon Aug 17, 2015 9:52 am
No, yours has individually-clamped levers on the throttle spindle, which means the ?250,000 OBL/flat-floor/welded louvre builders/sellers will want your parts for more than the cost of a new Burlen setup. Nice to see someone accidentally making money with an E-type instead of working the usual investment schtick.
Post by Heuer » Mon Aug 17, 2015 10:03 am
Vegard wrote:Did the Mangoletsi kit come for 3.8s as well?
Yes, and for both LHD and RHD.
Vegard
Norway
#10
Post by Vegard » Mon Aug 17, 2015 3:54 pm
Well, I must admit, it would be tempting to "waste" the 3.8 inlet on the worthless S1.5 though, just to annoy the ?150.000 car guys 😂
Thanks guys for the feedback. I need to contact SNG B tomorrow.
David Oslo
Norway
#11
Post by David Oslo » Mon Aug 17, 2015 5:35 pm
You've just doubled the value of your car :D
Series 1.5 with 3.8 liter manifold :D
David
Vegard
Norway
#12
Post by Vegard » Tue Apr 05, 2016 12:44 am
Now with the correct kit ;)
JOHN HAY
Post by JOHN HAY » Wed Apr 20, 2016 5:36 pm
What is the advantage of the change?
Post by Heuer » Wed Apr 20, 2016 6:17 pm
More pedal travel, smoother operation, adjustable pedal position in all directions, better fuel economy: viewtopic.php?t=3512
A really worthwhile upgrade which makes the car even more of a pleasure to drive.
Vegard
Norway
#15 Re: Mangoletsi wire throttle upgrade 1.5 :)
Post by Vegard » Wed Nov 30, 2016 1:02 pm
Getting there....
Simonpfhc
#16 Re: Mangoletsi wire throttle upgrade 1.5 :)
Post by Simonpfhc » Wed Nov 30, 2016 2:59 pm
I've got that linkage kit too - beautifully made ;-)
Noticed that you have the vacuum take-off on the rearmost carb body. Not too critical, but you probably want it on the carb nearest the distributor, right at the front.
Cheers.
62 3.8 FHC
91 Porsche 928GT
Vegard
Norway
#17 Re: Mangoletsi wire throttle upgrade 1.5 :)
Post by Vegard » Fri Dec 16, 2016 10:23 pm
Damn. Too late now. Longer hose :wink:
