"What you need is one of these,i made my first one when I was an apprentice nearly 50 years ago, just clip it to earth, and the cable to the CB on the coil, (- for negative earth cars, + for positive earth cars) you don't even to remove your distributor cap, its the quickest way I know to check a condenser,A.T"
I used it and it correctly diagnosed a dead condenser. Connected, the car ran perfectly. Disconnect the earth clip and runs terribly. You do get a bit of a shock through the condenser when clipping it to earth but it sure beats replacing the damn thing, only to find that it wasn't the problem in the first place.
