heater return pipe
Wicker
#1 heater return pipe
Post by Wicker » Fri Oct 23, 2015 1:42 pm
With respect to a 1965 E-Type FHC
At the risk of appearing over nit picky could someone advise the proper mounting of this pipe on the right hand side of the engine block. Should the brackets be attached to specific manifold studs?
Many thanks
Wicker Francis
1965 E-Type FHC LHD in restoration
Post by abowie » Fri Oct 23, 2015 9:45 pm
You'll find that they will only fit properly on the correct studs.
The longer bracket goes on the second stud from the front, the short bracket on the third from the rear.
Wicker
Post by Wicker » Mon Oct 26, 2015 1:41 pm
Perfect, Andrew
Thank you
Wicker Francis
