petrol leak on Stromberg carb
rolando38
#1 petrol leak on Stromberg carb
Post by rolando38 » Thu Oct 29, 2015 8:44 pm
hello
When I started my Jag today I first let the ignition on a few minutes to listen to the Tic-Tic of the fuel pump, and it did'nt completely stop, mybe stil one tic every 5 secs
then there was a strong smell of fuel when I opened the bonnet; some fuel was coming from the small holes on the link between the foremost carb and the air intake
see pic
there is also some fuel coming from beneath the same carb
is this the usual overflow when floater is blocked ? I tried to hit it with a hammer but no difference
what would you recommend ?
can I fire - er I mean start- the engine ?
2+2 1970
ralphr1780
Post by ralphr1780 » Thu Oct 29, 2015 9:22 pm
Rolando, I certainly would not fire the car under such circumstances, even though with engine running the fuel pressure would drop resulting in less leak. This is indeed the symptom of a blocked float or a blocked needle valve. Time for serious overhaul, for both strommies.
Ralph
'69 OTS + '62 OTS - Belgium
Post by malcolm » Fri Oct 30, 2015 9:36 am
If hitting it with a hammer didn't work, it must be serious... :D
Post by mgcjag » Fri Oct 30, 2015 9:57 am
Hi Ronaldo....Agree with Ralph....A complete rebuild of your carbs would be worthwhile. . Steve
rolando38
Post by rolando38 » Fri Oct 30, 2015 10:36 am
good thud with metallic hammer on carb and it stopped
carbs overhau is on my list !l
2+2 1970
jellypig
Post by jellypig » Sat Nov 07, 2015 10:45 am
Call that a leak on a Stromberg carb?
No... this is a leak!
I think my main problem was a sticking valve into the float chamber. (I'd taken it off and squirted it readily with carb cleaner, refitted and re-tested here
As you can see it didnt always fall back down, (I guess it might have with fuel pressure behind it?) but I decided to change it anyway.
I spent some time talking (via email) to some really helpful people at Burlen and I thoroughly reccomend them for technical expertise, though in the end they didnt have stock, so I got some service kits "overnight" from Southern Carburettors. Fitted. Sorted. No Leaks.
I'm not "out of the woods" with my fuel system yet, I think I now have a starvation problem on warm re-start, but thats a problem for another day and I havent looked into that yet - but the car isnt the fire risk it once was.
Post by PeterCrespin » Sat Nov 07, 2015 2:51 pm
Just a bit of dampness then? :-)
Reminds me of the person in the USA who fitted his SUs upside down (true).
Mark Gordon
Post by Mark Gordon » Sun Nov 08, 2015 12:04 am
Maybe he was planning on shipping his car to Oz, Pete.
rolando38
Post by rolando38 » Sun Nov 08, 2015 6:53 pm
very impressive, I hope you do not smoke ...
2+2 1970
