Re fitting my new water pump after the old one gave up the ghost. Do I use gasket goo and any recommendations for Anti freeze and the mix I should use.
I have searched Anti freeze in the search box but it comes up with lots of topics not even mentioning the word anti freeze. I never seem to have any joy with the search facility. Am I doing something wrong?
Water pump, anti freeze , gasket goo and search facility
#1 Water pump, anti freeze , gasket goo and search facility
Tony (E typed)
Tony
Tony
Hi Tony...just done a search..Some info for you here viewtopic.php?t=2162&highlight=anti+freeze I always use Wellseal for sealing gaskets.
Re using search..I typed in anti freeze then just under it clicked on the search for all items yes it does come up with other topics bet anti freeze was there... Steve
Tony : I have a tube of wellseal. As it's very expensive , and the tube will last me for ever, I'll drop it off to you
Thanks again everybody. I must try and do more research before asking questions. Then again if we don't ask questions then the forum would be very thin and the knowledge base empty.
Chris, you must regret living near me
Tony (E typed)
Tony
Tony
