how to spot difference in models
frenchi
#1 how to spot difference in models
Post by frenchi » Wed Nov 18, 2015 5:25 pm
is there a measuring point i have a 67 shell how do i know if its 2+2 or fhc
Post by mgcjag » Wed Nov 18, 2015 5:48 pm
Hi Frenchi..the fhc door opening is approx 32in the 2+2 opening approx 42in this depend where you measure..but the 2+2 is quite a bit wider. Steve
frenchi
#3 window size
Post by frenchi » Wed Nov 18, 2015 7:40 pm
so side windows must be 10 inches bigger then the fhc i have been offered fhc but i need 2+2 ones,after your measurements,will keep looking, tried barratts only stock glass at 50 quid a side
#4 Re: how to spot difference in models
Post by PeterCrespin » Thu Nov 19, 2015 2:39 am
frenchi wrote:is there a measuring point i have a 67 shell how do i know if its 2+2 or fhc
The 2+2 has flat floors lower than the FHC floor, which has footwells in 67. Also the 2+2 has welded-in B-posts where the FHC has open sides with a bolted-in B-post
