Steering rack attachment plate
Peter27
#1 Steering rack attachment plate
Post by Peter27 » Wed Dec 09, 2015 5:20 pm
During a routine health check of my RHD '63 FHC, I noticed that the lock-nut on the (driver side) lower outer set-screw/bolt which passes through the steering rack bracket and onto the chassis frame, was only just about engaged on the thread. Turning it with a spanner quickly revealed the thread was shot and the bolt was clearly not long enough. I then checked the other side and noted the bolt went in from the front of the car (and seemed the correct length), rather than from the rear as the offending set-screw had done. Referring to the manual (and internet), it seems the driver side should have spacer tubes on these bolts but can someone confirm if this is correct, or does it depend on the year of manufacture (because they are missing on my car)?
1963 3.8 FHC
Post by 1954Etype » Wed Dec 09, 2015 5:26 pm
Spacers on pinion side of rack.
Post by mgcjag » Wed Dec 09, 2015 5:29 pm
Hi Peter... have a look at this thread some photoes that may help viewtopic.php?t=5101&postdays=0&postord ... k&start=20
Peter27
Post by Peter27 » Wed Dec 09, 2015 6:39 pm
Thanks gentlemen. Spacers it is then (along with the correct bolts!) on the pinion side.
1963 3.8 FHC
