I drove my MGA today
#1 I drove my MGA today
Post by abowie » Sat Feb 13, 2016 7:19 am
Over the last 6 months or so I have been rebuilding an MGA.
I drove it for the first time today.
It's actually not too bad. For one thing there's a lot more leg room than my 3.8.
http://www.mgexp.com/phorum/read.php?2, ... sg-3107246
#2 MGA
Post by cactusman » Sat Feb 13, 2016 7:48 am
Good for you. Never driven an MGA but my MGB has bigger footwells than my 3.8....bet your 3.8 is faster though :D
Post by abowie » Sat Feb 13, 2016 8:11 am
Yes, the MGA is no rocket..
#4 MGA
Post by cactusman » Sat Feb 13, 2016 8:19 am
Gorgeous car though....bet the weather is Australia is better then here....
andrewh
Post by andrewh » Sat Feb 13, 2016 9:05 am
I have a TD which has longer footwells than an E type, but is almost as challenging to get into! I like MGs and would love to restore a B for my daughters to enjoy, but don't have enough time in the day. Enjoy your MGA
1962 3.8 Series One FHC
Post by malcolm » Sat Feb 13, 2016 10:24 am
I love the look of the MGA. I had an MG Magnette ZB, a saloon with the same engine as the MGA (except for smaller carbs and a different manifold) I fitted the bigger MGA 1600's carbs and manifolds. Helped a bit, but still not the quickest Bunny in the field.
Is yours the 1500 or the 1600?
Got a picture?
Post by christopher storey » Sat Feb 13, 2016 12:40 pm
Lovely car, and now much sought after here in UK. But, when I looked at a Twin cam about 2 years ago, I found the door pillars very intrusive at my age. Sad!
Moeregaard
Post by Moeregaard » Sat Feb 13, 2016 1:28 pm
The MGA is a nice car--slow, but nice. A '62 1600 Mk II was my daily driver in the early 1980s. As a college student, I didn't have a "pot to p*ss in or a window to throw it out of" so the simplicity and cheap maintenance had a lot of appeal--even if I did have to wrap my books and papers in plastic bags on rainy days. It never let me down in the six years I owned it. Much of the slowness seems to come from the poorly spaced gearing more than anything else.
What really transforms the car is the installation of the five-main 1800cc lump from the MGB. We did this with another MGA and it was a major improvement, not to mention a very simple swap and much easier than fitting something Japanese. If I were to do this again, a warmed-over 1800 and five-speed gearbox would be first on the list.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Post by abowie » Sat Feb 13, 2016 9:27 pm
malcolm wrote: Got a picture?
There are lots more pics in the thread on the MG site
Still fiddling with front wiring so no grille yet.
Post by abowie » Sat Feb 13, 2016 9:32 pm
malcolm wrote: Is yours the 1500 or the 1600?
Got a picture?
1600 bored out to 1650cc, early MGB head with a good porting job. Will hopefully go OK once I get it tuned properly.
#11 Re: MGA
Post by abowie » Sat Feb 13, 2016 9:33 pm
cactusman wrote:Gorgeous car though....bet the weather is Australia is better then here....
High temp has been 28*C all week...
Post by abowie » Tue Feb 16, 2016 6:56 am
What a great little car!
Characteristically unable to restrain myself I have built a moderately "worked" engine. Initial road tests were disappointing..
Standard carb settings have been lean. Today I installed rich needles and some heavier carb piston springs to richen things up.
WHAT FUN! It's like a little go-kart! Put your foot down and it tries to rev to kingdom come. Not fast, but sticks to the road like glue and sounds like an angry dwarf!
Post by abowie » Fri Feb 19, 2016 6:27 am
I thought I should let you all know that I adjusted the MGA tappets today.
I am quite experienced with doing E Type engine heads. I can usually have one perfect within an hour.
The MGA took me 90 seconds. Giggle.
Post by christopher storey » Fri Feb 19, 2016 7:45 am
If you can check and adjust 1 tappet every 11.25 seconds you're either a genius or you have a very slow watch :D :D
Post by abowie » Fri Feb 19, 2016 8:51 am
You can do 2 at a time and you use the starter to advance the engine.
It really does take that little time!
Post by christopher storey » Fri Feb 19, 2016 5:36 pm
Ah, but being a nitpicker I would say that you are not getting each tappet on the back of the cam if you use the starter . Bearing in mind how tappety B series engines can be, I regard accuracy as being rather important
