Can anyone tell what is stamped on the tags, I know that the front brake master is DOM which is date of manufacture and vbm 4705.But what about the rear and clutch ?
Adam
aluminium tags on master cylinders on 63 3.8
budmarston@aol.com
#2 Aluminum Tags on 3.8 Master Cylinders
Hello, Adam -
The following may help -- I researched these for two 1961 E-types. You can use the same VBM numbers but use later DOM dates for your car if you are making tags.
Lower Brake Master Cylinder Operating Front Brakes (see J-30, p. 135) (fitted to Chassis No. 885156 and subsequent)
DOM. 18 12 61
VBM. 4705
Upper Brake Master Cylinder Operating Rear Brakes (J-30, p. 136) (fitted to Chassis No. 885156 and subsequent)
DOM. 18 12 61
VBM. 4706
Clutch Master Cylinder (J-130, p. 58) (fitted from 885001 to 886218)
DOM. 12 12 61
VBM. 4044
Lower Brake Master Cylinder Operating Front Brakes (see J-30, p. 135) (fitted from 885001 to 885155)
DOM. 7 09 61
VBM. 4038
Upper Brake Master Cylinder Operating Rear Brakes (J-30, p. 136) (fitted from 885001 to 885155)
DOM. 7 09 61
VBM. 4039
DOM. 12 9 61
VBM. 4044
DOM. 18 12 61
VBM. 4705
DOM. 18 12 61
VBM. 4706
DOM. 12 12 61
VBM. 4044
DOM. 7 09 61
VBM. 4038
DOM. 7 09 61
VBM. 4039
DOM. 12 9 61
VBM. 4044
These are the tags from the master cylinders on 876024. Maybe this will help a little if you blow up the picture.
Bud has everything right.
Dave Schinbeckler
'61 E-type OTS
'05 X-type Estate
'88 Ferrari Testarossa
'82 Dodge W-150
'61 E-type OTS
'05 X-type Estate
'82 Dodge W-150
