Forum Access Problems
#1 Forum Access Problems
Post by Heuer » Tue Apr 26, 2016 9:47 pm
We have moved servers and there are some problems. Please bear with us if you have access problems and keep trying.
Stephanie Plum
Wales
#2
Post by Stephanie Plum » Tue Apr 26, 2016 10:27 pm
David if you need a financial donation to help get stuff fixed I'd be happy to pay an annual sum to use this forum. It's a great place and I'm sure I'm not alone in this.
265bhp
Post by 265bhp » Tue Apr 26, 2016 10:51 pm
+1...Same principle we have for the DDK early 911 web forum I have used for 10 years
Post by Heuer » Wed Apr 27, 2016 6:20 am
Thanks but it is not financial. You will have to bear with me whilst I try and resolve the technical issue's. If the Forum disappears please check on Jag-Lovers for updates.
Tony
Post by Tony » Wed Apr 27, 2016 7:10 am
Dave,
When I log on, it now sents you to a advert for E type Uk. On the top right hand corner is a forum tab which directs you through to the forum as we know it.
Tony
Tony (E typed)
Tony
Post by Heuer » Wed Apr 27, 2016 7:19 am
You may start seeing this message when you click on the 'Forum' tab from the main web site.
I am working on it!
JimmyS
Post by JimmyS » Wed Apr 27, 2016 8:33 am
David,
As stated above I do see the 404 message when I try to logon, also as stated above by Tony, clicking on the 'Forum' link at the top right of the page gets me back in to the index where I would expect to be, however this is via a new tab on my browser (IE11) whilst the 404 tab stays put.
Good luck in getting to the bottom of this!
Jim
1964 FHC Project
1E20078
Post by Heuer » Wed Apr 27, 2016 8:56 am
If you have the Forum bookmarked in your browser it will most likely have this address: index.php
Change it to http://forum.etypeuk.com/ (i,e. delete the index.php part) and you will go straight to the Forum and bypass the 404 message. Thanks to Angus for figuring that one
JimmyS
Post by JimmyS » Wed Apr 27, 2016 9:20 am
Hi David,
I'm afraid the shorter address makes no difference to me. I still get the 404 with the option to click through on the top right. Also, logging out takes me to the 404 page as well, not the index page with the partially hidden threads.
Jim
1964 FHC Project
1E20078
Post by Heuer » Wed Apr 27, 2016 9:28 am
Clear your browser cache and try again. Both of the above links should now take you straight to the Forum.
Post by abowie » Wed Apr 27, 2016 9:33 am
Works fine for me David.
I usually link to new posts and that works too.
Cheers,
AB
JimmyS
Post by JimmyS » Wed Apr 27, 2016 10:46 am
I cleaned out my cache and tried again, only to have the same problems. I cleaned it out again to record the changes to the URLs at the top of my browser as I went through each step, and this time, when I logged out, I was taken to the cut down index page as was usual.
All now appears to function as it did before. Thank you.
1964 FHC Project
1E20078
Post by Heuer » Wed Apr 27, 2016 12:13 pm
OK. I think we have everything stabilised and back to normal for the moment. More work to do over the coming days but that should not impact on day to day running. Thanks for your patience.
Post by Heuer » Wed Apr 27, 2016 4:51 pm
Big than you to Marcus Holland (owner of E-Type UK) and his team for sorting things out so quickly. There is still work to do but based on what I have seen all potential problems will be quickly overcome.
Post by mgcjag » Wed Apr 27, 2016 5:16 pm
Many thanks to all involved on restoring this valuable resource......much appreciated
Mich7920
Post by Mich7920 » Wed Apr 27, 2016 5:25 pm
A BIG Thanks for all the people who work for our confort.
I was a littel bit anxius in loosing this data bank but all is fine now.
Thanks again !!!
Mich
Michel
Post by Gfhug » Wed Apr 27, 2016 5:29 pm
I'll add my thanks to all who have sorted this out.
I'd be lost without the help I've received on the forum and am very grateful it is back up and running properly.
Thank you
paydase
Post by paydase » Thu Apr 28, 2016 8:09 pm
Big thanks too to those who devote time and energy for all of us freely here.
Serge
1964 (3.8) FHC
1961 OTS
sjclark
Post by sjclark » Fri Apr 29, 2016 11:43 pm
Many thanks to all those who have been working to get this excellent resource back on line.
S 1.5 FHC
dal2.0litrefrogeye
Post by dal2.0litrefrogeye » Tue Jun 14, 2016 9:54 am
Good to have it back .big thanks to all those working on it . I'd have no problem with a subscription charge if it ever comes to that 👍👍
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
