Strange distributor cap fault
#1 Strange distributor cap fault
Post by christopher storey » Sun May 08, 2016 5:08 pm
I have just been getting my 4.2 OTS ready for the summer, and found it wouldn't start. Removing the dist cap revealed oil had got inside the distributor and been distributed ( pun intended ) everywhere . Whether it had come down the coil lead - most likely - or come upwards was hard to tell. I cleaned it all up, checked for spark at the coil lead ( good spark to earth ) and tried again. Dead . I then started checking continuity and found that there was no transmission of current through the carbon brush . Could a soaking of the brush in oil over a period of months have caused this ?
I replaced the brush with a spare, and away we went . Strange
Post by mgcjag » Sun May 08, 2016 5:21 pm
Hi Christopher.... good news that you got it going.....oils are used in some transformers as an insulator......so quite possible that soaking into your carbon bush caused it to fail ele trically......after all you replaced it and it worked
tim wood
Post by tim wood » Sun May 08, 2016 5:28 pm
Possibly oil leaking from the coil, running down the lead ?
Coil failure imminent?
Post by christopher storey » Sun May 08, 2016 5:40 pm
Ah, yes, Tim, that's a good point , and I shall check for it.
