Out side bonnet latch quiry
wynnski
#1 Out side bonnet latch quiry
Post by wynnski » Sun May 15, 2016 5:02 am
Hello
Does anyone know if the 4 captive nuts for the bonnet latch, 2 below the voltage regulator and 2 by the chassis plate, were carried over on the vehicle bodies after the outside latch was dropped?
andrewh
Post by andrewh » Sun May 15, 2016 9:59 am
I have seen several cars that had the holes for the angle bracket with bolts in them, but no OBL brackets. So yes, I would suggest that they did but not sure when that was dropped
1962 3.8 Series One FHC
wynnski
Post by wynnski » Sun May 15, 2016 7:11 pm
Does anyone know how long the captive nuts carried on for, after they dropped the outside latch?
Dave K
Post by Dave K » Sun May 15, 2016 9:51 pm
My flat floor which is 21st November '61 doesn't have any angle brackets only two self tappers each side where the brackets would have been.
It looks like the holes were still being put in in where you suggest and Jaguar simply put self tappers in to fill the holes.
I've never noticed bolts in the holes then again I've never really looked, I know of a UK car in Canada that also has self tappers fitted.
Fixed Head
Post by Fixed Head » Sun May 15, 2016 10:06 pm
For roadsters, the accommodation on the body for both versions of latches probably continued for somewhere around a thousand more cars (total LHD and RHD) after the outside latches. Don't think it's actually documented anywhere.
