Bonnet 8-way connector wiring
iani
#1 Bonnet 8-way connector wiring
Post by iani » Wed Jun 22, 2016 7:41 pm
Can anyone point me at a list of the wiring on the 8-way plug by pin number, S2 car if that makes a difference.
thanks
Ian
E-type - TBC
1968 Triumph GT6 Mk1
#2 Re: Bonnet 8-way connector wiring
Post by Heuer » Wed Jun 22, 2016 7:52 pm
Check the Forum KB, last thread. The wiring of the S2 bonnet is the same as the S1.
#3 Re: Bonnet 8-way connector wiring
Post by mgcjag » Wed Jun 22, 2016 8:40 pm
Also pin numbers shown on the wireing diagram inside a small circle symbol for each wire to a lamp or indicator..
gts2
#4 Re: Bonnet 8-way connector wiring
Post by gts2 » Thu Jun 23, 2016 4:37 am
Headlight connector pinouts .jpg (95.77 KiB) Viewed 5361 times
'62 3.8 OTS, '64 3.8 FHC
iani
#5 Re: Bonnet 8-way connector wiring
Post by iani » Thu Jun 23, 2016 6:31 am
Thanks chaps.
Ian
E-type - TBC
#6 Re: Bonnet 8-way connector wiring
Post by Heuer » Thu Jun 23, 2016 9:10 am
#4 (centre terminal) is used for the mythical fog lights - a red/yellow cable.
iani
#7 Re: Bonnet 8-way connector wiring
Post by iani » Thu Jun 23, 2016 10:10 am
Heuer wrote:#4 (centre terminal) is used for the mythical fog lights - a red/yellow cable.
Pic above shows #6 as red/yellow, hopefully the wiring won't be as dirty as the rest of the loom and can work it all out, I have bought a replacement bonnet loom so that will all be fresh.
E-type - TBC
#8 Re: Bonnet 8-way connector wiring
Post by Heuer » Thu Jun 23, 2016 10:27 am
My mistake - #4 is for the horns on the 3.8. #6 is Fog lights.
iani
#9 Re: Bonnet 8-way connector wiring
Post by iani » Thu Jun 23, 2016 10:36 am
Heuer wrote:My mistake - #4 is for the horns on the 3.8. #6 is Fog lights.
I'm doing your headlight wiring upgrade, will be using #6 for power supply from alternator.
E-type - TBC
