Series 1 1/2 clutch flexi hose mounting bracket position
johnj
#1 Series 1 1/2 clutch flexi hose mounting bracket position
Post by johnj » Sat Jun 25, 2016 1:04 am
Hi all rebuilding a series 1 1/2 e type that was in bits when I got it, I have come to do clutch pipes and need to know were the bracket
That goes on the engine to hold the flexi pipe bolts to ,I have bolted the upper one one the frame but not sure which bolt to use on the bell housing can anyone help pic would be much appreciated. Thanks John
johnj
#2 Re: Series 1 1/2 clutch flexi hose mounting bracket position
Post by johnj » Mon Jun 27, 2016 11:31 am
so of all the thousands of E types out there no body knows were this bracket goes :sad:
I just need to know what bolt hole to use, a pic would be very help full.
please some one out there in E type world just a Pic to help me get the car finished
Many Thanks in advance John
gts2
#3 Re: Series 1 1/2 clutch flexi hose mounting bracket position
Post by gts2 » Mon Jun 27, 2016 11:49 am
Hope it helps
Clutch bracket.JPG (104.88 KiB) Viewed 5348 times
'62 3.8 OTS, '64 3.8 FHC
paulsco
#4 Re: Series 1 1/2 clutch flexi hose mounting bracket position
Post by paulsco » Mon Jun 27, 2016 11:55 am
Hi John,
I dont have any pictures, but there is a slightly twisted bracket that bolts to one of the bolts that hold the engine to bellhousing at the back of the block where it bolts to the sump.
http://www.sngbarratt.com/CatalogueProd ... 150&a=2150
No 30 in this link.
http://www.sngbarratt.com/ProductDetail ... e57ac0&l=7
I hope this helps.
johnj
#5 Re: Series 1 1/2 clutch flexi hose mounting bracket position
Post by johnj » Mon Jun 27, 2016 12:30 pm
great stuff thats the pic I needed,
very much appreciated :thankyouyellow:
nefematic
#6 Re: Series 1 1/2 clutch flexi hose mounting bracket position
Post by nefematic » Mon Jun 27, 2016 5:13 pm
That picture shows an extremely nice clean car, congratulations!
Martin Scherz
Late S2 1970 OTS US LHD
johnj
#7 Re: Series 1 1/2 clutch flexi hose mounting bracket position
Post by johnj » Tue Jun 28, 2016 11:53 am
gts2 wrote:Hope it helps
It sure does ,thanks so much really appreciated :thankyouyellow:
