Perforated cable ties and buttons - At Last, A Tool ?
rfs1957
#1 Perforated cable ties and buttons - At Last, A Tool ?
Post by rfs1957 » Mon Jun 27, 2016 5:02 pm
Is this what everyone uses or have I invented a good idea ?
I found fitting these a real pain and could never get them satisfactorily tight until I forged the end of an old screw-driver, and I've now been using it for a couple of years.
Because it's very thin, you can push against the button whilst putting tension on the strap -
and then the strap will bite on the button -
and the fork then serves to push the top strat hard down over the button
This has GOT to be of interest to someone, somewhere ?!
#2 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by PeterCrespin » Mon Jun 27, 2016 6:11 pm
You need to get out more Rory - possibly out of France if Brexit is any guide :-(
I'd say it's a nice solution in search of a problem. After all, they're not hose clips, just a way of keeping the harness from dragging on the road. But hey, if you like 'em so tight you can see the electrons bulging the wire upstream, it's a neat tool. Reminds me of the clutch spring tool on old Brit bikes.
Glad you're back and posting though. :wrench:
#3 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by christopher storey » Mon Jun 27, 2016 9:37 pm
I do not think that being very tight is very desirable. And, IIRC, the last lot I bought was very easy to fit, because the holes had a slight longitudinal slit extension which made them very easy to fit .
#4 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by abowie » Tue Jun 28, 2016 9:59 am
The trick with this stuff is NOT to cut it to length.
Put a button in the last hole on the roll.
Wrap the tie around the engine frame and loom, with the cut end facing away from you and the button on a firm section on top. The roll goes under from front to back, and comes out above with the roll towards you.
Use the thumb of one hand to hold the end in place against the frame. Then with your other hand pull the roll hard towards you, stretching the tie towards you. Under tension the holes elongate. Pull the hole down over the button.
NOW cut off the roll.
neil4444
#5 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by neil4444 » Tue Jun 28, 2016 10:37 am
I just pull tight, push down over the pimple with a small bore socket & cut to length.
Oh, and in the winter I warm the roll before using.
Neil
1962 S1 OTS
1967 S1 FHC
#6 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by PeterCrespin » Tue Jun 28, 2016 12:54 pm
neil4444 wrote:I just pull tight, push down over the pimple with a small bore socket & cut to length.
Same here, except I use my thumbnail. The advantage of that is I never lose the special tool and if it breaks I have a spare. Now if my name was Churchill I could sell my nail clippings...
rfs1957
#7 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by rfs1957 » Tue Jun 28, 2016 3:49 pm
Well, well, that went down like a lead balloon eh ?
Tightness : not attempting to strangle wiring or w.h.y. but I could never get to that "next" hole that gave a better shape to the banding, and meant it stayed put.
Re-using : it is much easier to re-use again the bands you've removed with this tool, witness the comments from our friend abowie that the way to fit them is "not to cut them to length first" - perhaps implying that some of us then chuck them away ? I just re-fit them, and wanting to do so was one of the principal reasons I spent 5 minutes on the anvil and with a die-grinder to make the tool.
Yes, yes, Peter, I ought to get out more often.
#8 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by MarekH » Wed Jun 29, 2016 1:05 pm
Why not just drop the cable tie into a cup of boiling water and it'll go on nice and easily. Failing that, use a hair drier on it for a minute.
rfs1957
#9 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by rfs1957 » Fri Jul 01, 2016 4:37 pm
If the cars are worth so much, it indeed makes sense to just chuck the straps away every time you remove them.
On the other had, a small roll of perforated tape is £13.52 and the tool costs £0.20p
PS the holes in the SNGB tape are still the correct round shape and not slit.
#10 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by Heuer » Fri Jul 01, 2016 9:06 pm
Original buttons were white, reproductions are black.
ETTony
#11 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by ETTony » Tue Jul 05, 2016 6:31 pm
Where do you guys source the buttons.
I can only find them for 11p +vat each, half a crown in old money each :wow:
I would expect a never ending bag of the things for a few quid.
Tony in Devon
#12 Re: Perforated cable ties and buttons - At Last, A Tool ?
Post by mgcjag » Tue Jul 05, 2016 6:44 pm
Hi Tony....what you gat and what you expext are two different things :bigrin: have a look here strap and buttons http://www.sngbarratt.com/ProductDetail ... b9ba7e572a
