Tightening the upper timing chain
jagwheels
Ireland
#1 Tightening the upper timing chain
Post by jagwheels » Thu Jul 07, 2016 6:26 pm
Hi Lads. I have a bad rattle from the upper timing chain and went to tighten it and the locking plunger on the adjustment that tightens the chain was stuck. It tapped in easy but I cant get it out now. Any idea on how to get it out now.
Regards John
John Gill
1966 FHC SWB
#2 Re: Tightening the upper timing chain
Post by abowie » Thu Jul 07, 2016 10:00 pm
It'll often stick if there is tension on the chain. Wiggle the vernier wheel back and forth until it pops out.
If you can't budge it loosen the chain and remove the lock nut, lock washer then the vernier wheel, Be careful not to drop them into the sump. BE aware that the plunger is spring loaded and has nothing to restrain it once the wheel is off, so keep a finger on it to stop it shooting out as well. Then you can gently release it and put it all back together again.
jagwheels
Ireland
#3 Re: Tightening the upper timing chain
Post by jagwheels » Fri Jul 08, 2016 4:30 pm
Thanks Andrew I will give that a go
John Gill
1966 FHC SWB
jagwheels
Ireland
#4 Re: Tightening the upper timing chain
Post by jagwheels » Sat Jul 09, 2016 6:09 pm
So I took it apart and the plunger still stuck solid. Discovered it would move in a circle so I got a grips on it and moved it from left to right and worked it out after about 30min of struggling with it.
John Gill
1966 FHC SWB
#5 Re: Tightening the upper timing chain
Post by mgcjag » Sat Jul 09, 2016 6:16 pm
Hi John......is the spring in there.....
jagwheels
Ireland
#6 Re: Tightening the upper timing chain
Post by jagwheels » Sat Jul 09, 2016 7:05 pm
Yes the spring was there it was just stuck fairly solid and I should not of taped it in, Once out and cleaned works fine.
John Gill
1966 FHC SWB
#7 Re: Tightening the upper timing chain
Post by abowie » Sat Jul 09, 2016 9:39 pm
Excellent!
Always a bit scary when you take that nut off...
jagwheels
Ireland
#8 Re: Tightening the upper timing chain
Post by jagwheels » Sun Jul 10, 2016 6:46 am
Yes it would be very easy to drop one of the bits in to the engine. Thanks
John Gill
1966 FHC SWB
