I have located from two different sources components that should, if advertised correctly, provide me with a complete braking / clutch system for my 1962 roadster that at some point has had a later braking update installed, which I now wish to return to original.
The purchased parts will need to be restored and checked over and there will quite possibly be a few other parts still needed. Does anyone know of a company who could rebuild / restore these items to a first class standard.
I don't sending abroad if needed.
Thanking you in advance
Alex
Kelsey Hayes braking system
commemorative74
Topic author - Posts: 52
Mark Gordon
#2 Re: Kelsey Hayes braking system
If you don't mind sending abroad, White Post Restorations do a first rate job. Check out their website:
http://www.whitepost.com/
#3 Re: Kelsey Hayes braking system
Hi Alex,
It's a fairly easy job to restore all the Kelsey Hayes components. Mike Cassidy's guide is in the Knowledge Base here...
http://www.myetype.co.uk/forum/viewtopic.php?f=16&t=700
Re any missing parts you can just check what you have against the Clutch & Brake sections of the S1 Parts Catalogue (also in Knowledge base) then talk to Richard Smith re anything you need.
Also Hutsons can provide the Kelsey Hayes service parts (belows / bushes, etc).
They can also arrange for re-sleeving of brake & clutch m/cs (can't remember who they used) but others on here have used Classicar Automotive
Address: Unit A
Alderley Road
Chelford
Cheshire
SK11 9AP
Telephone: 01625 860 910.
The one thing I would definitely recommend (from getting it wrong initially) is to photograph the alignment / position of the brake pedal shaft before taking it apart !
HTH,
Address: Unit A
Alderley Road
Chelford
Cheshire
SK11 9AP
HTH,
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
commemorative74
#4 Re: Kelsey Hayes braking system
Thanks Mark and Neil for your informative response.
Both units should be turning up towards the end of this week and I currently have access to a friends complete unit who has his in storage at the moment whilst his car is being restored, so I will use his as a template which will help in assessing any additional parts needed and the general overall condition of the unit.
If I do get stuck I will no doubt be giving your suggested contact a call to see if the can help.
Alex
Alex
#5 Re: Kelsey Hayes braking system
Richard Smith has produced some parts for the 3.8 brake controls:
C17239 Rubber Buffer - #13
C17240 Spacing Collar - #15
C17241 Belleville Washer - #16
C20787 Eccentric Barrel Nut (later cars) - #18
C17243 Eccentric Barrel Nut (earlier car) - #18
UFN425/L Castellated Slotted Nut - #19
As usual you can contact Richard direct on 01270 780954 or email rmj@rmjsmith.fsnet.co.uk
#6 Re: Kelsey Hayes braking system
What Rory has said above is correct, and it is worth reading his original thread on the KH booster which is thorough and detailed.
Don't be put off by the apparent complexity though. As long as you rebuild it with the right components in the right place it doesn't matter whether you truly understand the engineering or not. I rebuilt the booster in my 3.8, and the brakes, all standard, are excellent and as good as the brakes in my other two cars.
