Hose connecting pipe - C16999
ralphr1780
#1 Hose connecting pipe - C16999
Post by ralphr1780 » Wed Jul 20, 2016 7:26 am
Busy on fitting hoses and clips.
Struggling with the inter-hose connecting pipe pump to bottom of radiator: C16999.
The pipe I have, which is new coming from one of the usual suppliers, is having a wide bend making it impossible to connect the two hoses together (even if these would be shortened): http://www.sngbarratt.com/ProductDetail ... 861572&l=7
On the plate in the spare parts book, it is illustrated having a simple sharp 90° bend.
Is the "real" C16999 supposed to be like in the spare parts book or am I missing something?
Have spent already a couple of hours on this, with nice bruises on the front arms.
Thanks for help!
Ralph
'69 OTS + '62 OTS - Belgium
#2 Re: Hose connecting pipe - C16999
Post by rswaffie » Mon Jul 25, 2016 7:43 pm
I'm having the same problem - having purchased the same items from SNG. I got everything to connect, but it doesn't look right and not as neat as the original (but badly aged) hoses. I am looking into this at the moment to see if i have got something wrong in the fitting. If you get it resolved before I do, let me know! I will of course post a reply if I get is sorted before you.
#3 Re: Hose connecting pipe - C16999
Post by mgcjag » Mon Jul 25, 2016 8:17 pm
Have you looked in the factory fit section to see if there is anything to help
#4 Re: Hose connecting pipe - C16999
Post by rswaffie » Mon Jul 25, 2016 8:21 pm
Good point - I'll have a look.
#5 Re: Hose connecting pipe - C16999
Post by PeterCrespin » Mon Jul 25, 2016 9:22 pm
Is the pump inlet correctly angled, and the radiator outlet? I've seen mismatched versions of both.
ralphr1780
#6 Re: Hose connecting pipe - C16999
Post by ralphr1780 » Tue Jul 26, 2016 8:05 am
I have looked as well in the factory fit and could not find any lead.
I found a post http://www.myetype.co.uk/forum/viewtopi ... 999#p42879 which does illustrate the same issue. And I find that the final setup of Rory is somehow not satisfactory.
The pump and radiator outlets are both angled correctly, and when I fit the hoses it is clear a simple 90° sharp elbow is needed such as illustrated in the wsm and spare parts book.
Guess will have to pass with the hoses by a plumber to get a suitable elbow.
Ralph
#7 Re: Hose connecting pipe - C16999
Post by abowie » Tue Jul 26, 2016 8:28 am
I recall having to shorten both ends of one on my 3.8 to get it to fit...
#8 Re: Hose connecting pipe - C16999
Post by rswaffie » Tue Jul 26, 2016 11:57 am
Thanks abowie & ralphr1780 - I followed the threads and the pics from 2011 are most useful. It suggests that the issues with the pipe/hoses from SNG still exists as cutting down the hoses seems the only recourse. Not pretty, but as long as it works.....
