Bonnet safety catch and bracket
andrewh
#1 Bonnet safety catch and bracket
Post by andrewh » Tue Aug 16, 2016 4:19 pm
In my pursuit of the slight and occasional creaking noise when I drive over slightly underrating ground, I have alighted upon my non original replacement safety catch and bracket. It would appear that the two come into contact with each other when the bonnet is in the lock down position. Any slight movement of the bonnet would cause a squeaking of metal to metal. Has anyone else found this with new replacement parts here? I previously had to bend down the catch bracket to get it to line up but it then broke in half. Only slightly bent it honest! I am at a loss here without an original of either that has not been mauled to compare to. I reckon that the effect of the touching is also slightly holding up the centre of my bonnet from seating perfectly along the top as well. I guess I was wondering whether anyone makes these correctly to original design and measurements?
1962 3.8 Series One FHC
#2 Re: Bonnet safety catch and bracket
Post by mgcjag » Tue Aug 16, 2016 6:01 pm
Hi Andrew..AJ autocraft who are always at the jag spares day makes some good parts..worth a call http://www.ajautocraft.co.uk/partsnopic.htm
andrewh
#3 Re: Bonnet safety catch and bracket
Post by andrewh » Tue Aug 16, 2016 8:52 pm
I will give Andy a call and see what he has for the bonnet catches. His work is normally very nice indeed. thanks for the idea.
288gto
Russia
#4 Re: Bonnet safety catch and bracket
Post by 288gto » Tue Aug 16, 2016 9:32 pm
Hi Andrew, I bought one from him in stainless and it's very good quality so recommended. When I bought mine he only did the catch for some reason and not the bulkhead part.
andrewh
#5 Re: Bonnet safety catch and bracket
Post by andrewh » Wed Aug 17, 2016 7:20 am
thanks Simon. Good to know. I need to do some measuring work to see why are fouling each other. One or both of the replacement parts will be the culprit no doubt.
Keith in Norfolk
#6 Re: Bonnet safety catch and bracket
Post by Keith in Norfolk » Wed Aug 17, 2016 2:12 pm
I had the same squeak as you , a smear of grease sorted mine out :bigrin:
andrewh
#7 Re: Bonnet safety catch and bracket
Post by andrewh » Wed Aug 17, 2016 4:09 pm
thank you Keith was this the centre catch rubbing on the retaining bracket behind the cam covers? They should not be in contact i would have thought in any case. As a trial I have put some insulation tape on it to see whether that is the squeak. Have not been out in it yet to try but seems likely it is the culprit.
